Good Afternoon G-Shock Rangeman,
If you have reset the module and keep getting different readings something is affecting your watch. I am reading your post which you wrote on 151205 and you make the observation that while the watch is on your wrist your altimeter readings are correct and constant. You have my friend thus, answered your own question. You see these watches take in consideration first and foremost ambient temperature which will affect altitude readings always. The mentality behind this is that as you go higher in elevation air density diminishes and thus, ambient temperature will go down (or be cooler than at sea level) which is affected by your actual geographical location.
I did find this chart which gives you the year around average ambient temperature readings for your area; they should yield valuable information and improve your readings.
Climate[edit]
Kaunas has a humid continental climate (Köppen climate classification Dfb) with an average annual temperature of approximately 6 °C (43 °F).
Despite its northern location, the climate in Kaunas is relatively mild compared to other locations in similar latitudes, mainly because of the Baltic Sea. Because of its latitude, daylight in Kaunas extends 17 hours in midsummer, to only around 7 hours in midwinter. The Kazlų Rūda Forest,[39] west of Kaunas, create a microclimate around the city, regulating humidity and temperature of the air, and protecting it from strong western winds.
Summers in Kaunas are warm and pleasant with average daytime high temperatures of 21–22 °C (70–72 °F) and lows of around 12 °C (54 °F), but temperatures could reach 30 °C (86 °F) on some days. Winters are relatively cold, and sometimes snowy with average temperatures ranging from −8 to 0 °C (18 to 32 °F), and rarely drop below −15 °C (5 °F). Spring and autumn are generally cool to mild.
[hide]Climate data for Kaunas
Month Jan Feb Mar Apr May Jun Jul Aug Sep Oct Nov Dec Year
Record high °C (°F) 9.3
(48.7) 14.8
(58.6) 20.2
(68.4) 27.9
(82.2) 31.4
(88.5) 32.8
(91) 34.9
(94.8) 34.7
(94.5) 29.7
(85.5) 23.9
(75) 16.7
(62.1) 11.1
(52) 34.9
(94.8)
Average high °C (°F) −2.6
(27.3) −1.4
(29.5) 3.5
(38.3) 10.7
(51.3) 17.9
(64.2) 21.0
(69.8) 22.2
(72) 21.9
(71.4) 16.7
(62.1) 10.8
(51.4) 4.4
(39.9) 0.0
(32) 10.4
(50.7)
Daily mean °C (°F) −5.2
(22.6) −4.3
(24.3) −0.4
(31.3) 5.8
(42.4) 12.4
(54.3) 15.8
(60.4) 16.9
(62.4) 16.4
(61.5) 11.9
(53.4) 7.1
(44.8) 1.8
(35.2) −2.3
(27.9) 6.3
(43.3)
Average low °C (°F) −8.5
(16.7) −7.6
(18.3) −3.6
(25.5) 1.8
(35.2) 7.4
(45.3) 10.9
(51.6) 12.4
(54.3) 11.8
(53.2) 8.1
(46.6) 4.0
(39.2) −0.5
(31.1) −4.9
(23.2) 2.6
(36.7)
Record low °C (°F) −35.8
(−32.4) −36.3
(−33.3) −26.3
(−15.3) −12.0
(10.4) −4.9
(23.2) −0.2
(31.6) 4.4
(39.9) 0.3
(32.5) −3.2
(26.2) −13.7
(7.3) −22.5
(−8.5) −28.5
(−19.3) −36.3
(−33.3)
Average precipitation mm (inches) 37.7
(1.484) 29.9
(1.177) 32.8
(1.291) 40.5
(1.594) 49.9
(1.965) 71.4
(2.811) 77.3
(3.043) 81.2
(3.197) 58.6
(2.307) 51.3
(2.02) 48.8
(1.921) 47.8
(1.882) 627.0
(24.685)
Average precipitation days 22.3 18.6 18.6 11.3 13.4 13.2 12.1 13.0 11.3 14.0 18.8 20.9 187.5
Average relative humidity (%) 88.1 85.8 81.3 68.8 69.4 72.8 75.7 76.8 80.8 85.6 90.0 89.1 80.4
Mean monthly sunshine hours 40.3 67.8 127.1 174.0 251.1 264.0 257.3 238.7 159.0 99.2 42.0 27.9 1,748.4
Source #1: World Meteorological Organization[40] NOAA (extremes)[41]
Source #2: Hong Kong Observatory (sun only)[42] Weatherbase (precipitation and humidity)[43]
Landmarks[edit]
Try taking altitude readings with the watch on your wrist and at the same time and location and you will see how accurate the watch is. However, if you keep having issues please let me know and I will be happy to do more research for you.
